Linksys Switch Help
startrek1333
I was given a linksys SRW224G4 switch .. It seems to work fine on some ports and others dont ..
I am tring to log into it to see what the current config is .. but no luck ..
I cant seem to find what ip address its pulling to be able to log into the web interface ..
I have tried the blue cable , and using hypertermail but with no luck .. I dont have com 1 or 2 as an option on my latop just com 3 ..
So looking for advice on how I can log into this switch and rest it back to factory specs so then I can go though and setup how i want ..
I have also tried netstat and arp -a too with no luck either ..
Help please ..
thanks ..
startrek1333
Anyone ???
Hi Josh,
Here is a link that might help. Unfortunately this is the only way I know to access the switch when you do not know the IP or password.
http://www.opendreams.net/jesse/doc/linksys_srw_switch_password_recovery.txt
Hope this helps.
Thanks for the link Robert,
only trouble I see is i am running windows 7 on my laptop and I dont have a com port .. and the blue console cable that I do have looks like it plugs into the nic port ..
So confused ..
I understand your confusion with the console cable. The cable you would want is a serial to serial cable. At home I use a USB to serial converter which helps since not many computers come with a COM port anymore.
As for the software side, I recommend using Putty which will allow you to connect the same a hyper-terminal.
I hope this clears up your confusion.
