Mac Filtering on Cisco 8-Port SG 200-08 Smart Switch.
kinemetrics
Is this smart switch possible to do Mac Filtering? If yes, please explain how to enable mac filtering on this device?
Thanks!
Tom Watts
Hi Devin, the switch does support port security which can allow certain MAC address to use a particular port or limit the number of MAC addresses connecting to a port. This switch does not have a dynamic ARP inspection.
For more information about this reference page 155
http://www.cisco.com/en/US/docs/switches/lan/csbss/sg200/administration_guide/78-19562.pdf
Unfortunately I cannot give a specific example to the sg200-8 model since I don't have one on hand. However, here are a couple documents I created for the bigger brother, the SX300 series. Hopefully it is comparably close enough for you to get what you want if port security is what you're looking for.
https://supportforums.cisco.com/docs/DOC-27720
https://supportforums.cisco.com/docs/DOC-27753
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
