Meantime between failure numbers
kan
Hello people,
My name is Mike. Its the first time Im using the Cisco Support Community.
Im looking for the MTBF numbers of 3 Cisco products.
Sometimes they are provided in the datasheet, but for these products I couldnt find them.
Ive contacted the Cisco 'helpdesk' many times. But its hopeless.
So I hope I could get an answer here.
I need the MTBF numbers of the following devices:
-Cisco SB SG 300-10;
-Cisco SB SG 200-20;
-Cisco SB SF 100-16.
Thank you in advance!
Kind regards,
Mike
streaves
Hi Mike -- Thanks for participating in the Small Business Support Community.
Cisco SB SG 300-10 - 74294 hours
Cisco SB SG 200-20 - See data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps11229/data_sheet_c78-634369.html
Cisco SB SF 100-16.- 368,473 hours
Thanks for asking,
Stephanie Reaves
Cisco Small Business
Hello Stephanie,
Thank you for your reply.
I can sure use this information!
I forgot to mention the MGBLX-1 Transceiver.
Could you provide the MTBF for this product as well?
Kind Regards,
Mike Kan
streaves
Hi Mike -- Always glad to help. Going to have to dig a little deeper for the MGBLX-1 MTBF. Please stand by.
Stephanie
Still waiting on the _exact_ number but in the meantime can tell you that for similar products the MTBF is 70,000 hours, which should provide a reference point. Hope this helps.
Stephanie Reaves
