memory utilization for sg500
deepakkris92
hi,I am unable to find memory utlization for sg 500 switch?please help me for this
7 Replies 7
deepakkris92
i need for cli
Jitendra Kumar
show memory summary
#show process memory    #show process memory history
Jitendra
It does not appear for switch sg500.I have tried it
show system tcam utilization
The show system tcam utilization EXEC mode command displays the Ternary
Content Addressable Memory (TCAM) utilization.
Syntax
show system tcam utilization [unit unit-id]
Parameters
N/A
Default Usage
unit-id—Specifies the unit number. (Range: 1–8)
Command Mode
EXEC mode
Example
The following example displays TCAM utilization information.
6.21 show services tcp-udp
Use the show services tcp-udp Privileged EXEC mode command to display
information about the active TCP and UDP services.
Syntax
switchxxxxxx# show system tcam utilization
TCAM utilization: 58%
System: 75%
Unit
TCAM utilization [%]
58
57
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/cli_guide/CLI_Nikola500_1_3_5.pdf
Jitendra
Tcam utilization and memory utilization are both different.the only command
I can use is show tech support memory.that too.I really don't understand
how do I calculate.I can give you the screenshot of the memory
Any update on this issue?
Thx
share the output  show tech support memory.
Description (partial)
Symptom: Memory utilization information is missing from Dash-lets for Cisco MS200x , SG220,SG300,SG500 device. Conditions: Device Type: MS200x , SG220, SG300,SG500 Deploy device health to Nikola and Eastman devices and check the result from Inventory > Device Management > Network Devices ->(Select Device)->System Summary-> Memory Utilization Memory utilization information is missing from Dash-lets for Cisco MS200x , SG220,SG300,SG500 device
Jitendra
