Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 1262 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300Hardware Installation Guide - Catalyst 12...
  • 5970 Views
  • 4 replies
  • 17 Helpful votes
hi, i have a priblem in connecting antminers only 4 come online and if i remove this 4 then the other 4 online and i take new ips of 1 gbps then i connect more 4 and i have 50 pic and i want to connect to 1 isp can u suggest any option or metherd
uddin9101 by Level 1
  • 1327 Views
  • 4 replies
Hello, I realize this is a forever ago question but I am needing some current confirmation on this switch before I build my network out.  So this switch has four 10-gigabit uplink ports - XG1 thru XG4.  Can I use XG4 to uplink to the router/firewall ...
EvanC75 by Level 1
  • 1145 Views
  • 2 replies
Hi there. I'd like to know if there's a command I can run to turn off paging on my SF302 switch. So for example, when I run the "show logging" command on the CLI, I'd like to it return all the results instead of prompting me to hit space bar or enter...
juleedev by Level 1
  • 62573 Views
  • 9 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
