mini printer vlan problem
Aquiles
Frequent Visitor
Frequent Visitor
i have a cisco switch with 4 vlans, i have a printer on native vlan and it can be ping, but when we send to print it just stuck on the queue on the computer,   but it respond to ping, but if we move to another vlan not native i cant even ping,  im using switch sf300-24pp small bussisness, what can i be missing.
19 Replies 19
             >...i can ping but cant print, its wierd, if i tag , i cant even ping.
                - What is the printer model ?
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Its a posiflex mini printer ethernet
    - Does the printer need additional and or it's own drivers (to be installed) ?
    - You may want to install this tool on your PC : ftp://ftp.gastro.pl/pub/ISO/PPLanMgr_Instruction.pdf
       and check if it can give assistance for setup and diagnostics.
    - For drivers , if needed look at : https://www.posiflex.com.tw/de-DE/Download/index/driver/POS-Drucker
    - You may also invoke their support , https://www.posiflexusa.com/contact/
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
This thread looks like it is partly a duplicate of your other question at https://community.cisco.com/t5/switches-small-business/cant-ping-from-another-vlan/td-p/5156754 where I have explained routing between VLANs for you.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Mark Elsen
  - Adding to other remarks of mine :
         - If  are your on a Windows (10 or other) system  : Open the windows Device Manager
            Check if it can be seen under Printers , usually near below ; if it does not show up
            then it could mean that an (additional) driver is needed.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
