12-15-2011 01:49 PM
I want to "stack" a couple 300 series gigabit switches with fiber using a pair of MGBSX1 GBICs and a single LC to LC patch cable.
Is there a minimum supported patch cable length in this configuration?
Solved! Go to Solution.
12-15-2011 02:00 PM
Howard,
Thank you for posting. You should have no issues using a short fiber patch between the switches. Just make sure the fiber doesn't bend too sharply and get damaged.
12-15-2011 02:00 PM
Howard,
12-19-2011 10:03 PM
Hi mpyhala,
Thanks for your response. I picked up a 1 meter aqua cable and it appears to be working fine.
