06-15-2015 09:15 AM
I have this issue on my network for some reason my network tester (fluke linkrunner at) is detecting the port of other switch even if I connecting to my other switch ports ( example: connecting over an stack of six cisco sge 2000 switches in port 6 of switch 6 and on my tester shows I am connecting to a prosafe switch on port 9/.) Sometimes happen the same and shows the sg500 port.
I suspect this cause a loop on my network (we have some network issues) can you please guide me to have the right setting to uplink this switches together?
I already enable STP!
06-16-2015 06:40 AM
What have you selected as your root bridge for the spanning tree topology?
Have you enabled Per Vlan Spanning tree?
06-21-2015 04:14 PM
Sounds to me your network tester is being flaky.
