Need Help InterVLAN routing
Whatever help I can get is much appreciated. I am working on a Cisco 891 and I am trying to setup interVLAN routing so that 10 VMs on an ESXi server can communicate with each other. I am connected to the router via command port and here is the configurations that I did.
Enable DHCP
Router (config) # ip dhcp pool NET-POOL
Router (dhcp-config) # network 172.20.1.1 255.255.0.0
Router (dhcp-config) # default-router 172.20.1.1
Router (dhcp-config) # exit
Router (config) # ip dhcp excluded-address 172.20.1.1 172.20.1.255 (router & server)
Router # copy run start
Router # show config
Create Vlans
Router> enable
Router # configure t
Router (config)# vlan 101
Router (config-vlan) # name User
Router (config-vlan) # vlan 102
Router (config-vlan) # name Public
Router (config-vlan) # vlan 103
Router (config-vlan) # name External
Router (config-vlan) # vlan 104
Router (config-vlan) # name Internal
Verify vlans created
Router> sh vlan-switch
Add interface to vlan
Router (config) # interface fa1
Router (config-if) # switchport access vlan 101
Router (config-if) # no shut
Router (config-if) # exit
Router (config) # interface fa2
Router (config-if) # switchport access vlan 102
Router (config) # interface fa3
Router (config-if) # switchport access vlan 103
Router (config) # interface fa4
Router (config-if) # switchport access vlan 104
Add ip to vlan
Router (config) # int vlan 101
Router (config-if) # ip address 172.20.10.1 255.255.255.0
Router (config-if) # int vlan 102
Router (config-if) # ip address 172.20.20.1 255.255.255.0
Router (config-if) # int vlan 103
Router (config-if) # ip address 172.20.30.1 255.255.255.0
Router (config-if) # int vlan 104
Router (config-if) # ip address 172.20.40.1 255.255.255.0
I know that I most likely did something wrong but I don't know what it is any help would be extremely appreciated.
Francesco Molino
First of all your DHCP pool isn't correct because you're configuring a /16 while your vlans are all /24.
You can remove it by issuing the command:  no ip dhcp pool NET-POOL
You'll need to create 1 pool per vlan.
Example for VLAN101 (172.20.10.0/24)
ip dhcp pool VLAN101
 network 172.20.10.0 255.255.255.0
 default-router 172.20.10.1
ip dhcp exclude 172.20.10.1 172.20.10.5 --> Let's assume you want to keep the 1st 5 IPs for future usage.
You'll repeat this for each vlan by changing the dhcp name, network and default-router info.
Then, each subnets can talk to each other as ip routing is enabled by default on a router which is its primary usage.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
Francesco
Alright I did that, but I check the status and they are marked as down see below
Router#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Async1                     unassigned      YES unset  down                  down
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
FastEthernet5              unassigned      YES unset  down                  down
FastEthernet6              unassigned      YES unset  up                    up
FastEthernet7              unassigned      YES unset  down                  down
FastEthernet8              unassigned      YES unset  administratively down down
GigabitEthernet0           unassigned      YES unset  administratively down down
Vlan1                      unassigned      YES unset  up                    up
Vlan101                    172.20.10.1     YES manual down                  down
Vlan102                    172.20.20.1     YES manual down                  down
Vlan103                    172.20.30.1     YES manual down                  down
Vlan104                    172.20.40.1     YES manual down                  down
Interfaces on which you configured to be in access mode should be connected and then the svi related to vlan associated will come up.
Francesco
Sorry for the late reply, I have been busy the last week. When you say the interfaces should be connected, what exactly do you mean by connected?
Connected means they should be up with a cable connected to each of them.
Francesco
