New firmware change for DAI and ACL not blocking
Peter __
I still can't work out how to report stuff to Cisco so I'm just going to post here.
SG350-10 10-Port
In 2.5.7.85 ACL is done first then DAL in 2.5.8.12 DAI is done first then ACL
Traffic can now leak under DHCP ports in 2.5.8.12
part of ACL rule
Priority    Action   Logging     Protocol     Source IP Address    Destination IP Address   Source Port    Destination Port
5353       Permit  Disabled     UDP           Any Any                  255.255.255.255   0.0.0.0    68                      67
7000       Deny    Disabled     UDP           Any Any                   Any                       Any         68                      67
bind to port GE1 Input ACL with DAI
IP Source Guard GE1
DHCP Snooping Trusted Interface GE2
In 2.5.7.85 DHCP would be allowed if its broadcast and renews on a broadcast just fine and blocks unicast traffic, with 2.5.8.12 the Priority rule 7000 no longer blocks unicast traffic with DAI on.
8 Replies 8
marce1000
                 >...I still can't work out how to report stuff to Cisco so I'm just going to post here.
   - FYIhttps://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
 M.
its grayed out to open a case
 - I can't see that on that page, did you login (too) and or then tried :
                   https://mycase.cloudapps.cisco.com/start?referring_site=smbcontacts
 M.
 M.
Yes logged in and that link sends my back too
https://mycase.cloudapps.cisco.com/case
maybe I need to make a new login?
   - Note sure , may depend on owning active service contracts.
 M.
Peter __
can someone else make cases for me the Cisco site will not let me its broken.
One thing I forgot to mention , you may try one of the phone numbers
according to your region. Then mention your problem and or query your
eligible service status. M.
Peter __
It seems in order to post a case to Cisco you have to be part of a business which I'm not so any one reading my bug finds by all means open a case for them.
The ACL above was put on the IP Source Guard port for Input ACL but if you put that ACL on the DHCP Snooping port for Output ACL then it drops Priority rule 7000 unicast traffic.
