01-24-2015 09:28 AM
Hi there, i hope you can help me i just created a vlan on a L3 Cisco SG300-28MP and works great but only if my RV042G firewall is off what can i do ? thanks in advance !!!
01-24-2015 12:15 PM
That is way to little information,
Show us a diagram of your network and tell us from where to where you cannot go.
Looking for Network Specialists (Cisco,Juniper,SonicWall,Palo-Alto)?
Make sure you contact iNetworks to get the most of your network.
Visit us at www.i-networks.us
01-26-2015 09:21 AM
Thanks i attached a fast diagram of my network i share the internet and Progress Database on my site in Chevrolet to Mercedes Benz on VLAN 192.168.0.2 and works good but only if the firewall is disabled if i enable the firewall on RV042G the internet and the database connection is gone thanks in advance
01-26-2015 11:58 AM
Let me see if I understand the diagram correctly.
The RV042G has a VPN built going to The Chevrolet Site.
The RV042G also connects to the BMW Site.
Both Sites are able to use the internet and the Database as long as the firewall is not enabled.
Is that what you are trying to say?
Regards.
01-26-2015 12:07 PM
Yes exactly, both sides are connected to the RV042G but in Mercedes Benz i Have an Ubiquiti Router with a different subnet 192.168.19.XXX and everything is working good but only if my Firewall is disabled, sorry for my english !!!
01-26-2015 12:25 PM
Could you post screenshots of your firewall configuration on the RV042G?
01-26-2015 01:27 PM
01-26-2015 01:43 PM
Thank you for posting the rules.
I am curious about the first two rules, why are you forwarding all the traffic to those two addresses? On my experience that always creates problems.
I will also like to look at your port forwarding rules.
Thank you
01-26-2015 02:20 PM
Thanks, i just made those two to see if mi vlan works with the Firewall Enabled and those rules but it doesn't work
01-26-2015 12:37 PM
No worries,
I now understand this. Well as someone already see we will need to check the firewall rules.
01-26-2015 01:25 PM
