no switchport port-security maximum 2 is not work
cisco-A20911954#show running-config interface gigabitEthernet 1/0/8
Building configuration...
Current configuration : 271 bytes
interface GigabitEthernet1/0/8
switchport trunk allowed vlan 250,4094
switchport mode trunk
authentication host-mode multi-host
authentication port-control auto
dot1x pae authenticator
end
cisco-A20911954#show port-
cisco-A20911954#show port-security ?
address Show secure address
interface Show secure interface
| Output modifiers
<cr>
Secure Port MaxSecureAddr CurrentAddr SecurityViolation Security Action
(Count) (Count) (Count)
Total Addresses in System (excluding one mac per port) : 1
Max Addresses limit in System (excluding one mac per port) : 2048
cisco-A20911954#show mac add
cisco-A20911954#show mac address-table inter
cisco-A20911954#show mac address-table interface GigabitEthernet1/0/8
Mac Address Table
Vlan Mac Address Type Ports
1 041d.c71f.1699 STATIC Gi1/0/8
Total Mac Addresses for this criterion: 1
cisco-A20911954(config)#interface GigabitEthernet1/0/8
cisco-A20911954(config-if)#no switchport port-security maximum 2
Maximum is less than number of currently secured mac-addresses.
7 Replies 7
marce1000
          - Try this procedure :
  1. Shutdown the port
  2. remove port-security (no port-security)
  3. reconfigure port security   (according to your intentions)
  4. no shutdown the port
 M.
Thank you for your feedback
cisco-A20911954(config)#interface gi
cisco-A20911954(config)#interface gigabitEthernet 1/0/8
cisco-A20911954(config-if)#shutdown
it does not solve my problem
           - What device model is this and what is the software version , that it is currently running ?
 M.
cisco-A20911954#show version
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 07:46 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
cisco-A20911954 uptime is 18 weeks, 16 hours, 33 minutes
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1446V3VR
Last reset from power-on
5 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 08:17:35:78:D3:00
Motherboard assembly number : 73-10219-09
Power supply part number : 341-0098-02
Motherboard serial number : FOC14464P7H
Power supply serial number : AZS143912L9
Model revision number : H0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S1U
System serial number : FOC1446V3VR
Top Assembly Part Number : 800-26859-03
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COMB600BRA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS-1U 12.2(55)SE1 C3750-IPSERVICESK9-M
Configuration register is 0xF
cisco-A20911954#show running-config interface Gi
cisco-A20911954#show running-config interface GigabitEthernet1/0/8
Current configuration : 84 bytes
shutdown
end
 - When the port is shutdown try :  default  interface GigabitEthernet1/0/8 , and try the intended configuration on  the port again , including the rest of the settings.
 M.
cisco-A20911954(config-if)#exit
cisco-A20911954(config)#defua
cisco-A20911954(config)#defa
cisco-A20911954(config)#default interface GigabitEthernet1/0/8
% Error(s) seen setting interface GigabitEthernet1/0/8 to it's default config
it's no work!
is this  a bug?
         - Reboot the device and try again (with default interface GigabitEthernet1/0/8)
 M.
