SG200 SFP Compatibility
damian.woz
We want to connect SG200 to Catalyst 2960X via optical fibre. Now on our SG200 (SG200-50P-K9-EU) switches are using D-Link DEM-311GT SFP modules.
We found module Cisco GLC-SX-MMD, that is compatible with Catalyst series switches, but there's no info about Small Business series. Someone has tried to run this module on Cisco SB?
Yiu Kay Lee
SG200 series support these SFP:
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/data_sheet_c78-634369.html
Product Ordering Number
Description
MFE Transceivers
MFEBX1
100BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 20 km
MFELX1
100BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 2 km
MFEFX1
100BASE-FX SFP transceiver for multimode fiber, 1310 nm wavelength, supports up to 10 km
MGE Transceivers
MGBBX1
1000BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 40 km
MGBLH1
1000BASE-LH SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 40 km
MGBLX1
1000BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 10 km
MGBSX1
1000BASE-SX SFP transceiver for multimode fiber, 850 nm wavelength, supports up to 550 m
This link provides compatibility information:
https://supportforums.cisco.com/document/140221/interconnect-cisco-sb-switch-and-catalyst-switch-sfp
To interconnect a Small Business switch with Cisco Catalyst switch, you need to use Cisco Small Business SFP on the Small Business switches, and Cisco traditional SFP on Catalyst switches. And the SFP on both sides should follow the same IEEE standard. The mapping table is shown below.
GE Transceiver
MGBSX1
GLC-SX-MM
SFP-GE-S
MGBLX1
MGBLH1
GLC-LH-SM
MGBBX1
GLC-BX-D
MGBT1
GLC-T
SFP-GE-T
FE Transceiver
MFEFX1
GLC-FE-100FX
GLC-GE-100FX
MFELX1
GLC-FE-100LX
MFEBX1
GLC-FE-100BX-D
Thanks.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | SMB Pre-Sales | yiulee@cisco.com | Phone +1 (855) 354-7776
richard_artes
I tested Cisco GLC-SX-MM in a SG200, it works fine. Not officially supported, but gives no problems. And it saves having to buy the officially supported SFP's!
Richard.
Very helpfull info
Stojan Savic
Just an update for anyone encountering this scenario -
Regarding the Cisco Start portfolio - Check out Page 27 of the Catalog (Click here)(pdf attached for convenience). This is the Nov 2017 catalog.
Though the GLC-LH-SMD transceiver shows as supported (Likely due to the EoS of MGBLX1).
The GLC-SX-MMD does not show up as confirmed compatible.
I've not tested the scenario myself as there are a few switch series within the Cisco Start portfolio, but as per Richard's response and the example you give of DEM-311GT working - It looks likely that you'll detect the GLC-SX-MMD in that series. But as per the link, nothing official.
Also I'd recommend checking out Salesconnect (click here). Plenty useful resources available.
Hope the info helps!
