NSS3000 FIrmware download
damienjweir
I am trying to setup a NSS3000 Cisco NAS device.
No matter how i set it up (Raid 0,1,5 jbod) and no matter how the share is configured, i cannot see it in windows!
Im hoping a firmware upgrade (or downgrade) will get it working but i cannot find any firmware anywhere as this is now a discontinued Cisco product.
Does anyone have firmware for this device that theyd share or any advise about why i cannot see or access the share would be greately apppricated
Damien
7 Replies 7
marce1000
   - Do you have any logs on the NSS or Windows (eventvwr) to get insights ?
      + You say you can not see the share in Windows : what happens if you try to access a share manually
         as in  CMD>\\NS3000\share\dir\file    (change this example accordingly of course)
  M.
logs attached.  I cant get access at all using \\sharename
       >...I cant get access at all using \\sharename
           -  What error do you get when trying ?
  M.
Don't recall exactly but the usual windows error you'd get if you tried to access a share that didn't exist.  Ie if you misspelt the share name
 - For troubleshooting the exact error is always important,
 M.
fair enough -- error is...
"Windows cannot access \\nas - check the spelling of the name. Otherwise, there might be a problem with your network. To try to identify and resolve the netowork problems, click Diagnose"
 - It looks the NSS isn't advertising anything on the network , I don't have detailed knowledge on it ; here are some hints  : - check if you can ping it
           - check status LEDs on the NSS
           - Use web interface , look at status and NAS configuration ,
   M.
