11-08-2020 02:49 PM
Cisco SG350-10 on 2.5.5.47
My NTP servers list show as down and do not update.
If I remove ntp.virginmedia.com and time1.google.com then add them back it shows as up.
11-08-2020 03:38 PM
check DNS able to resolve - when it down check are you able to ping that domain name?
i use public NTP stratum 1 or 2 to get accurate.
11-10-2020 09:05 AM - edited 11-10-2020 09:08 AM
DNS is fine as I said when I remove both time severs then add them back in it updates but it does not auto update after that.
03-06-2021 01:34 PM
Now on firmware 2.5.7.85 same problem god its hard to submit a bug and I can't work out how to open a case for it other then to post here.
03-08-2021 01:26 AM
Hello Peter,
The easiest way is to contact our technical support centre (STAC) on one of the following numbers:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
They can further handle your case and eventually file a bug at their discretion.
Martin
03-16-2021 05:23 PM
Thier STAC will not let me make a case.
04-23-2021 03:14 PM - edited 04-23-2021 03:16 PM
So something not right but the config of the SG350-10 is the same as my old SG300-10 in the end I setup windows to be a NTP server and IP to it which works.
DNS is by Bind at 192.168.53.2
VLAN 53 192.168.53.7/255.255.255.224
and VLAN6 192.168.255.254/255.255.255.0 is the source where it goes out for ntp.virginmedia.com
static routes
62.253.128.0/19 next hop 192.168.255.202 VLAN6
80.5.0.0/19 next hop 192.168.255.202 VLAN6
Like I say it works the first time and shows as up for ntp.virginmedia.com and then fails to update after that.
