Permanently disable pop-up notifications
Terabyte
I need to find a way to disable this permanently:
Syslog Notification (Information):
%AAA-I-CONNECT: New http connection for user cisco, source 192.168.1.176 destination 192.168.1.154 ACCEPTED
Every time I log into an SG350 swtich I'm harassed by these notifications.  I click on them and disable ("Disable Pop-up Syslog Notifications") them then I save the config and the very next time I login I'm harassed again.  I guess the next step is to disable logging all together but that seems like a drastic step.
Aleksandra Dargiel
Hi Teraybyte,
Indeed it does not seems to be saved in any config.
It is strictly related to Ram logs and not flash logs.
What I would recommend is to change severity of the loggings for RAM logs and this way the pop up it will bother you only in critical events.
Aleksandra
