ping failures on CBS250-24PP-4G-EU and CBS250-8PP-2G-EU
klaus.dotter
I have some CBS250-24PP-4G-EU Switches (12 pcs.) and some CBS250-8PP-2G-EU Switches (6 pcs.)
I get lost pings on each of the devices on some ports, at random times. I checked it with different ping tools for some weeks.
Now I changed one switch, who generates a lot of ping failures, I replaced that switch with an older switch from another manufactor. That older switch shows  no ping errors for days.
Each of the CBS250 Switches has the latest firmware installed.
I am grateful for any help.
Thx, Klaus
10 Replies 10
balaji.bandi
try remove smart port globally make it simple access port and test it.
can you post otehr switch report same like you posted to look ?
BB
thank you for your quick answer,
I deactivated the smartport, but that didn't change anything.
I'm also afraid that I can't permanently deactivate the smartport because the connected knx smart home devices can't be reached with it...
sorry, if my reply is twice in the post, i tried to remove one of them, but ...
klaus.dotter
provide show run from device., also post non cisco device ping output?
you can globally disable  and save it :
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2797-smartport-best-practices-CBS.html
BB
as I understand the best practices, smartport should be disabled, if vlans are configured. I work with vlans, but if I disable smartport, the knx device ist not reachable. i´ll try it again, but after the weekend, because it´s in a hotel/restaurant environment.
thanks for your support!
Means after configuring is the device lost connection?
BB
I disabled smartport globally, but only the administrative smartport, knx device and cameras lost connections. Now I disable operational smartport and disable auto smartport device detection and try again. I´ll let you know if it works.
You need to port level also.
BB
if I turn off adminstrative and/or operational smartport, the camera loses connection.
what do you mean with port level, e.g. for a connected camera with poe?
Most cases if you disable it should disable each interface level, some time the config will be still available as smart port, so check that also.
BB
