Port Security in Cisco SF 300-24 Switch
Yeadullah
Please suggest me
1. how to change  default user name and password through CLI mode of Cisco SF 300-24 switch
2. How to configure port security through CLI mode in  Cisco SF 300-24 switch
marce1000
 - Basically this device is not really configurable trough the CLI , for port security :
         https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4810-port-security-configuration-on-the-300-series-managed-switch.html
 As far as changing default username and password is concerned :
   https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
                         >... Follow the procedure(s) outlined in Accessing and Managing Your Switch
 M.
Martin Aleksandrov
Hi Yeadullah,
You can also configure port security and AAA including username and password on Sx300 switches through CLI. Please refer to the Sx300 CLI Guide https://www.storagenetworks.com/documents/cisco/cisco-series300-manual.pdf.
Those switches have been announced EoS/EoL since 2018 and the CLI guide has been removed from our site, however, you can use the above link.
Bear in mind the switch functionalities through the web GUI are also available on CLI.
Martin
