06-10-2014 01:21 PM
switch ESW540 on ethernet port present green led on the right of the port although there is no cable plug in.
06-12-2014 09:01 AM
Hi Acaz, this means the port is either hung or it is bad. You can try to clear the port by shutting it down and bringing it back up. You can also try to reboot or factory default the switch. If none of those clear it then the port is malfunctioning.
06-13-2014 12:28 AM
on other port work link , the port is broken :(
