Problem with SGE2010 and VLAN Routing
DCV-Technik
I have a routing problem with my SGE2010. My konfiguration:
1. Firewall
eth0 extern - VLAN 100
eth1 intern - 10.100.0.2 /17 VLAN 150
eth2 dmz - 10.100.128.2 /24 VLAN 200
eth3 iscsi - 172.160.100.2 /24 VLAN 800
2. SGE2010
The SGE2010 is running at the Layer 3 mode.
VLAN konfig.: Static, Port to VLAN (Untagged)
VLAN 100 Port 1-3 no IP Adress
VLAN 150 Port 4-18 10.100.0.1 /17
VLAN 200 Port 19-23 10.100.128.1 /24
VLAN 300 Port 25-30 10.100.1.1 /24
VLAN 400 Port 31-35 10.100.2.1/24
VLAN 500 Port 36-38 10.100.3.1/24
VLAN 800 Port 39-43 172.160.100.1
I connect the FW and the SGE2010:
FW eth0    -------    SGE2010 Port 1
FW eth1    -------    SGE2010 Port 4
FW eth2    -------    SGE2010 Port 19
FW eth3    -------    SGE2010 Port 39
ISP is connect at Port 2
The VLAN 200 and 800 work fine (if I use a IP from the VLAN Subnet and the GW 10.100.128.2 (VLAN 200), 172.160.100.2 (VLAN 800)
The VLAN 150 work, if I use a IP 10.00.0.XX with the GW 10.100.0.2
The VLAN 200, 300, 400 and 500 work only "inside". It is possible to get e connection to the Switch (webadmin 10.100.0.1) but i cannot connect to the FW or the Internet.
I try a static Route without succsess:
Dest. IP: 10.100.0.0; /17 Next Hop 10.100.0.2
Any suggestion are welcome :-)
Best regards,
Gerhard
Jo Kern
one thing is that you need a Default Gateway on the switch for the VLANs not connected directly to the outside
Static Route    0.0.0.0 /0 Next Hop 'ip address of FW"
and that means you have to assign an ipaddress to VLAN 100 also
