Questions on Cisco SF300-24P
tony08695
Hello there,
We are trying to config vlan 10 for data and vlan 20 for voice on the same port - port 1 of swtich SF300-24P to run both data and voice on different vlans.
How can we achieve this?
Do I have to add vlan 10 as an untagged vlan to port 1 and add vlan 20 as an tagged vlan to port 1?
If I do not want to assign the native vlan 1 to port 1, how can I remove it ? The GUI page - assign VLAN to port does not allow to remove it.
Aslo, what mode shall I set up on port 1? General, trunk or access ?
Appreciate your reply and helps.
Tony
21 Replies 21
Ivor Diedricks
Create VLAN 10 and make it untagged on that port. It will be the PVID for that port. Just use the default port mode of Trunk. VLAN 20 is added as a tagged VLAN.
Ivor, thanks for your kindly reply.
May I know how to remove VLAN 1 from port1 ?
The default mode for SF300-24P is trunk mode but in another switch 3650, you can have access mode for both voice vlan and data vlan on the same port.
When you create a new VLAN and add it as an untagged VLAN on a trunk port, the default untagged VLAN (VLAN 1) will no longer be present on that port.
It seems that Cisco IP phone 7960 or 7940 cannot get the power from SF300 switch.
Is there any workaround to get PoE working for phone 7960 and 7940 when it connects to SF300 switch?
Hard to believe SF300 switch does not support 7960 as we have too many in stock.
I am pretty sure that those phone models are old pre-standard CiscoPower.  They don't do PoE at all, so they can't get power from ANY PoE standard switch.
Ditch the phones.  Unless you go guy an old Cisco switch from eBay, you won't be able to power them at all.
Jesse, thanks for your response.
We have 40+ IP phone 7960/7940 here. I thought Cisco should release a firmware for 7960/7940 model so it can use on all new released PoE switches.
Sad to see it did not happen. A heavey waste in the investment !!!
Tony,
It's not a software thing. When the 7960/7940 phones were released many years ago, the IEEE 802.3af POE standard had not yet been defined, so those phones only supported Cisco pre-standard POE. After the 802.3af POE standard was ratified, thereby delivering POE interoperability between products from multiple vendors, switches and endpoints all started to support the new standard. The 79x1 phones and the new switches all support the standard.
Yea, those phones really are kind of old.  It has been years since they stopped selling those.
That being said, your best bet is to research which older switches will do Cisco prestandard power and go buy some off eBay or a gray market dealer.  It would be a shame to throw the phones away.
You need to do the math to figure out if it's cheaper to go with buying some old used gear that will support the phones, getting new phones, or what.
Cisco did drag their feed on doing the 802.3ae PoE implementation, just like they dragged their feet with LLDP-MED, but they did switch over.  Many newer Cisco switches are not supporting prestandard any more at all now.
Such are the perils of vendor-specific proprietary technologies.
Something like this may help you from PanOptic Technology. They'll eliminate the need for the wallwarts.
http://www.panoptictechnology.com/network-smart-adapters/
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center.
Currently there is no testing from Cisco to certify the use of any third party PoE adapters with any of out Small Business Equipment like the SF300 switches. While there are several out in the market, using third party equipment that has not been certified, can potentially work, they have an equal chance of not working or damaging equipment. Before using such devices I would make sure that they will replace any equipment that is damaged from the use of their products, because Cisco will not.
I am by no means saying that customers can not use third party equipment. I just want all of our customers to have all of the information.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
I tried this setup with connecting to a 2901 router instead, and cant get it to work. The phone is not associating to the correct VLAN. It gets the IP from the untagged vlan instead.  I tried it with general access to the router and trunk, but not having any luck, and the PC connected to the phone is not getting an IP either.
Hey try lldp to get the phones to register to the vlan that they are using.
Here are the steps for setting that up.
Hope it helps you out.
Well, I tried it, still didnt work, the phone doesnt show up under neighbors. We finally decided just to run them flat vlan 2. Let the customer get more switches for their data and another HWIC for the router.
Why would Cisco put their name on a switch that isnt compatible with their other equipment?
The phones you're referring to was End-of-Life's back in 2002/2003 and the new standard was ratified at that time. All products Cisco brought to market since that time supported the new standard - the SF300 also conforms to that standard. HEre is a list of Cisco phones supporting the standard. Alll  the SPA phones also support the 802.3af standard.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00808996f3.shtml
