Reserve IP addresses with Cisco SG300
FarisAga
Hello there. We have been using Cisco SG300-52 in our company for many years. The device has worked at default settings since the day it was installed.
But since last 1 week, we started to need reserved transactions with IP or MAC addresses.
Which way do I need to use for reservations?
Example: Reserve the address 192.168.0.10, even if the USER1-PC is turned off, and prevent any device/machine from obtaining the IP address of 192.168.0.10.
Martin Aleksandrov
Hello Faris,
First of all, you can use your DHCP server and statically allocate IP addresses ( a MAC address of the host is manually mapped to an IP address) to the PCs  (USER1-PC and USER2-PC) that performs the reserved transactions.
Then you can implement DHCP snooping, DHCP snooping binding database and IP source guard, in addition, to prevent other hosts from taking the IP address of their neighbours. With the DHCP snooping you ensure that hosts only use the IP addresses assigned to them when combined with the IP source guard.
1. From the switch web GUI you go to IP Configuration --> DHCP Server then assign IP addresses statically (device must operate in L3 mode).
2. Configure DHCP Snooping: IP Configuration --> DHCP Snooping Trusted Interfaces and choose the ports you would like to configure.
3. Configure DHCP Snooping Binding Database by adding required VLAN IDs, IP Addresses, Interfaces and MAC addresses.
4. Configure IP source guard (optional) - Go to Security --> IP Source Guard then enable it for both required interfaces and DHCP Snooping Binding Database.
Here are some step-by-step guides:
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5516-configure-dynamic-host-configuration-protocol-dhcp-trusted-i.html
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-500-series-stackable-managed-switches/smb3097-configuration-of-ip-source-guard-binding-database-on-sx500-s.html
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-500-series-stackable-managed-switches/smb3306-dhcp-snooping-binding-database-configuration-on-sx500-series.html
Martin
Martin Aleksandrov
Hello Faris,
Martin
Thank you for your response and help.
I will do the necessary work on the processes and write an answer to this topic.
Hello again.
The solution you suggested was sufficient for me and I achieved my goal.
Thanks again Martin.
I am glad you make it and works well for you!
Martin
