Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3022 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4610 Views
  • 1 replies
  • 16 Helpful votes
После замены старого TP-Link на Cisco SF110-24 у части устройств подключенных к нему, пропал доступ в интернет. При этом у большинства пользователей подключенных через этот коммутатор проблем не наблюдается. Сетевая карта получает от DHCP сервера дан...
plsys0001 by Level 1
  • 491 Views
  • 2 replies
Hello,I'm struggeling here... So! Here is how it works : I have 6 cisco SG350-20 switches daisy-chained. On the fourth of the line I have interpretation system that needs to send data on receivers connected to the other switches (1 receiver per switc...
Michke by Level 1
  • 573 Views
  • 1 replies
Greetings!I'm a Cisco noob with a couple SG350-10s, ciscored and ciscoorange (cisco orange is a 10P) and I sure could use some advise.  I moved to the Ciscos from a couple of netgears that were just awful, and what a wonderful upgrade!!  :)  Trouble ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
