RPS 2300 cable for SG550XG-24F
cadet
Level 4
Level 4
Hello!
Can you confirm than SG550XG-24F connect to RPS2300 using CAB-RPS2300= cable or CAB-RPS2300-E= ?
from documentation: Users may order either the CAB-RPS2300-E= compatible with Cisco Catalyst 3750E/3560E, 3750v2/3560v2, and 2960/2960S/2960P/2960X Series Switches or the CAB-RPS2300= compatible with all other network devices.
Hi @cadet
 From the doc:
 A 22-pin connector on the RPS end, and two varieties of connectors on the switch end:
    22-pin connector for Cisco Catalyst 3750E/3560E, 3750v2/3560v2, 2960/2960S/2960P/2960X Series Switches and 2911/2921/2951 routers (CAB-RPS2300-E=)
    14-pin connector for all other Cisco networking devices (CAB-RPS2300=)
CAB-RPS2300-E= Cisco Catalyst 3750E/3560E, 3750v2/3560v2, 2960/2960S/2960P/2960X Series Switches and 2911/2921/2951
CAB-RPS2300= Anything else.
Then in your case you must use CAB-RPS2300.
-If I helped you somehow, please, rate it as useful.-
Good Day.
On the page 11 you can see Back Panel photo with 22 pin RPS connector, so cable must be CAB-RPS2300-E=
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/550xg/quick_start/guide/en-US/550XG-QSG-en-US.pdf
