12-05-2017 07:39 AM - edited 03-21-2019 11:18 AM
I'm struggling to have the correct timeon my SG300 device. Manually time setting is for me not a good solution because each time the device has a power down the device lost the time. So I want to use a public SNTP server.
I tried already a SNTP unicast by IP address (128.249.1.1 en 128.2.136.71) or by name (wich are proposed) but the system stay on 11 july 2017.
I have no idea what else I can do ? Is there a possibility to force a time synchronisation ?
12-06-2017 05:46 PM
Hi @marcvb123
By name is not supporte but by IP should work. Follow this guide and make sure the switch has an gateway configured.
-If I helped you somehow, please, rate it as useful.-
12-07-2017 02:37 AM
Thanks for the reply.
I followed that procedure but there is no time synchronisation that happens.
If by name is not supported do you know public ip-addresses that should work ?
12-07-2017 04:25 AM
You can try:
128.138.140.44
128.138.141.172
12-07-2017 07:21 AM
Thanks. But not working.
Maybe I have to check, as you mentioned before, that there has been a gateway defined. Using the GUI it is not clear where I can check or define the gateway settings
