RV320 Private LAN Address Range
fmarshall3
I tried to set up an RV320 using 172.30.2.0/24 on the LAN - which is in the private address range of 172.16.0.0 – 172.31.255.255
I got the impression that it didn't or wouldn't work as I'd tried it more than once.
Using 192.168.111.0/24 did work right away.
Is this a limitation on the RV320?
kstiwari
Thanks for your query.
I have attached screenshots for RV320 where I changed the pool for the network ID you suspect to be problematic i.e.172.16.2.0/24
Cross check the version once you are on.I tested on a later version though. But i think it wont be causing a problem.
Reset the device and check if you are able to make the changes
K**bleep**ij Tiwari
kstiwari
K**bleep**ij Tiwari
Did DHCP work?  I also tried it and it appears it all works, including DHCP.
Thanks!
fmarshall3
We resolved it. Thanks for the support!
