Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2943 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4530 Views
  • 1 replies
  • 16 Helpful votes
HiI have a switch sg300-28 without fan and not show temp. I see that in motherboard is point to solder plug for fans and I test and it give on one pin 12V and on second about 3.3V.Is any chance to solder plug and connect fan. It works ok but in GUI n...
pepeEL by Level 1
  • 2823 Views
  • 7 replies
Hi, it is my first post, sorry but my english is very bad!!! I want to know how am i do to change the Vlan1`s IP address because the actual ip will be used in another vlan. Actually i haver 10 vlans in L3 mode (routing) implemented in it.I hope you u...
Javiermo0 by Level 1
  • 3428 Views
  • 6 replies
I'm trying to uplink a CiscoSG500 switch to a Meraki MS320 switch that has it's port 22 as Trunk Native VLAN 1, allowed VLANs all. I've connected the SG switch to port 22 on the MS320. My MS320 is connected to our firewall (MX100). The SG switch is s...
pg2241 by Level 1
  • 931 Views
  • 5 replies
Resolved! LLDP Voice VLAN
I'm setting up a Switchvox PBX with Digium D40 phones and Cisco SG200 switches.  The PBX doesn't do any CDP or LLDP advertizing so I do not expect the switch to automatically determine the voice VLAN ID and I need to manually set it.  How can I confi...
pauldugas by Level 1
  • 27078 Views
  • 14 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
