RV325 Saving Configuration to PC results in 0 byte xml files
HannsUllrich
Looking to upgrade firmware on our RV325. Went to save configuration files to PC and the resulting xml files have 0 byte of data. They are blank when opened.
Afraid to reboot or upgrade in this state.
-Hanns
Mark Elsen
             - How did you try to save the configuration ? Which commands were used ?  (e.g.)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I used the web interface to download to PC.
Tried using a USB, but it was not recognized, or at least never showed up as an option under Administration->Configuration Management->Copy/Save->Destination
-Hanns
       - Try another and or supported USB ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
