05-07-2024 12:39 AM
I want to secure one LAN port of my CBS350-48P switch. It is located to PoE camera outside the building.
It would be great to shut down the port, if another device is put into this port.
How can this be solved?
Best regards,
Heinz
05-07-2024 03:51 AM
- The small business devices don't support MAB (mac based authentication) , only dot1x which amongst authenticating services needs a supplicant on the device , so I don't think you can do it with those ,
M.
05-08-2024 12:02 AM
So, what else can I do to have a more secure solution?
ACL Binding (Port)?
