Secure Shell (SSH) Service on CBS250-8T-D Smart Switch
cpc1
The CBS250-8T-D  has no console port and I'm not sure what else this model does not support because the all-in-one datasheet for the 250 series doesn't state any other limitations.
Can I SSH or telnet to this device and get access to the full CLI?
Does it support Dynamic Routing, specifically RIPv2?
Thx in advance
marce1000
 - It should be accessible through SSH : https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-250-ag.pdf
   SSH Server
The SSH Server feature enables a remote users to establish SSH sessions to the device. This is similar to
establishing a telnet session, except the session is secured.
The device, as a SSH server, supports SSH User Authentication which...
 M.
balaji.bandi
CBS250-8T-D
These are for SOHO or SMB switches, with Limited features. SSH it does support you can do configure.
in terms of routing, it has Limited to only Static routing as per i know.
https://www.cisco.com/c/en/us/products/collateral/switches/business-250-series-smart-switches/nb-06-bus250-smart-switch-ds-cte-en.html
BB
