05-12-2011 04:42 AM
I have an issue with the sf-300 switch model, which i am depolying in lapsafe trolleys. The approach is to wake the laptops from the guest VLAN (20) with WOL have them authenticate with 802.1x and use DVA to put the ports in VLAN14 so updates can be pushed to them over night.
I have configured 802.1x, guest vlan and DVA which works initially, all host wake from WOL, the laptops successfully authenticate and are assigned to the VLAN (14). This remains stable for a time then the hosts fail reauthentication. I have also noticed that when a host is disconnected from a port and patched into another port the initial port remains in the authenticated state and the new port authenticates the client but the hostnames are missing on the 'authenticated hosts' page of the GUI, DVA fails. The ports display a port-failure message for a time then moves to failed reauthentication.
The only way I can get it to work again is to reboot the box. From the logs I can see the macs of laptops being rejected and I can also see attribute 26 being ignored. See log below. I am unsure as to why host are initially authenticated but reauthentication fails, is it not the same process?.
I have 11 of these switches and have configured 6 which all display the same behaviour. These switches are not CISCO I do not understand why they have badged them. The protocols/standards are implemented differently. If you incuded 'general ports' as an answer in a CISCO exam you would fail. There are also other issues I have noticed with these boxes, I am not impressed!!!.
Kind Regards
Daniel
05-12-2011 05:00 AM
2147483217 2011-May-12 12:44:15 Informational %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
2147483218 2011-May-12 12:39:31 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483219 2011-May-12 12:36:46 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483220 2011-May-12 12:22:12 Informational %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
2147483221 2011-May-12 12:19:42 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483222 2011-May-12 12:19:03 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
2147483223 2011-May-12 12:18:02 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483224 2011-May-12 12:16:34 Informational %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
2147483225 2011-May-12 12:02:38 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483226 2011-May-12 11:45:34 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483227 2011-May-12 11:39:50 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:7b was rejected on port e21
2147483228 2011-May-12 11:39:31 Informational %SEC-I-PORTAUTHORIZED: Port e30 is Authorized
2147483229 2011-May-12 11:39:31 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483230 2011-May-12 11:38:48 Informational %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
2147483231 2011-May-12 11:30:57 Informational %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
2147483232 2011-May-12 11:28:30 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483233 2011-May-12 11:21:24 Informational %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
2147483234 2011-May-12 11:19:18 Informational %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
2147483235 2011-May-12 11:19:03 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
2147483236 2011-May-12 11:18:02 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483237 2011-May-12 11:11:26 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483238 2011-May-12 10:54:22 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483239 2011-May-12 10:37:18 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483240 2011-May-12 10:34:23 Informational %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
2147483241 2011-May-12 10:21:25 Informational %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
2147483242 2011-May-12 10:20:14 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483243 2011-May-12 10:19:03 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
2147483244 2011-May-12 10:18:01 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483245 2011-May-12 10:03:10 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483246 2011-May-12 09:46:06 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483247 2011-May-12 09:29:02 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483248 2011-May-12 09:19:02 Informational %SEC-I-PORTAUTHORIZED: Port e26 is Authorized
2147483249 2011-May-12 09:19:02 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483250 2011-May-12 09:18:13 Informational %SEC-I-PORTAUTHORIZED: Port e27 is Authorized
2147483251 2011-May-12 09:18:13 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483252 2011-May-12 09:18:06 Note %COPY-N-TRAP: The copy operation was completed successfully
2147483253 2011-May-12 09:18:01 Informational %SEC-I-PORTAUTHORIZED: Port e48 is Authorized
2147483254 2011-May-12 09:18:01 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483255 2011-May-12 09:17:56 Informational %COPY-I-FILECPY: Files Copy - source URL flash://startup-config destination URL flash://mirror-config
2147483256 2011-May-12 09:17:14 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:ba:fb was rejected on port e27
2147483257 2011-May-12 09:17:07 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:bf:f4 was rejected on port e23
2147483258 2011-May-12 09:17:05 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:bf:34 was rejected on port e25
2147483259 2011-May-12 09:16:56 Warning %STP-W-PORTSTATUS: e26 of instance 0: STP status Forwarding
2147483260 2011-May-12 09:16:53 Warning %STP-W-PORTSTATUS: e27 of instance 0: STP status Forwarding
2147483261 2011-May-12 09:16:52 Informational %LINK-I-Up: e26
2147483262 2011-May-12 09:16:50 Warning %LINK-W-Down: e26
2147483263 2011-May-12 09:16:48 Informational %LINK-I-Up: e27
2147483264 2011-May-12 09:16:46 Warning %LINK-W-Down: e27
2147483265 2011-May-12 09:16:46 Warning %STP-W-PORTSTATUS: e23 of instance 0: STP status Forwarding
2147483266 2011-May-12 09:16:46 Warning %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
2147483267 2011-May-12 09:16:43 Warning %STP-W-PORTSTATUS: e25 of instance 0: STP status Forwarding
2147483268 2011-May-12 09:16:42 Informational %LINK-I-Up: e23
2147483269 2011-May-12 09:16:42 Informational %LINK-I-Up: e48
2147483270 2011-May-12 09:16:40 Warning %LINK-W-Down: e48
2147483271 2011-May-12 09:16:40 Warning %LINK-W-Down: e23
2147483272 2011-May-12 09:16:39 Informational %LINK-I-Up: e25
2147483273 2011-May-12 09:16:38 Warning %STP-W-PORTSTATUS: e26 of instance 0: STP status Forwarding
2147483274 2011-May-12 09:16:37 Warning %LINK-W-Down: e25
2147483275 2011-May-12 09:16:36 Warning %STP-W-PORTSTATUS: e27 of instance 0: STP status Forwarding
2147483276 2011-May-12 09:16:34 Informational %LINK-I-Up: e26
2147483277 2011-May-12 09:16:32 Warning %LINK-W-Down: e26
2147483278 2011-May-12 09:16:32 Informational %LINK-I-Up: e27
2147483279 2011-May-12 09:16:30 Warning %LINK-W-Down: e27
2147483280 2011-May-12 09:16:29 Warning %STP-W-PORTSTATUS: e23 of instance 0: STP status Forwarding
2147483281 2011-May-12 09:16:27 Warning %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
2147483282 2011-May-12 09:16:26 Warning %STP-W-PORTSTATUS: e25 of instance 0: STP status Forwarding
2147483283 2011-May-12 09:16:24 Informational %LINK-I-Up: e23
2147483284 2011-May-12 09:16:23 Warning %LINK-W-Down: e23
2147483285 2011-May-12 09:16:22 Informational %LINK-I-Up: e48
2147483286 2011-May-12 09:16:22 Informational %LINK-I-Up: e25
2147483287 2011-May-12 09:16:20 Warning %LINK-W-Down: e48
2147483288 2011-May-12 09:16:20 Warning %LINK-W-Down: e25
2147483289 2011-May-12 09:11:58 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483290 2011-May-12 08:54:54 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483291 2011-May-12 08:37:50 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483292 2011-May-12 08:20:46 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483293 2011-May-12 08:20:25 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:94 was rejected on port e20 , aggregated (1)
2147483294 2011-May-12 08:20:07 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:94 was rejected on port e20
2147483295 2011-May-12 08:20:07 Warning %SEC-W-PORTUNAUTHORIZED: Port e20 is unAuthorized
2147483296 2011-May-12 08:16:58 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:5c:b1 was rejected on port e2
2147483297 2011-May-12 08:16:58 Warning %SEC-W-PORTUNAUTHORIZED: Port e2 is unAuthorized
2147483298 2011-May-12 08:03:42 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483299 2011-May-12 08:00:04 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:be:13 was rejected on port e19
2147483300 2011-May-12 08:00:04 Warning %SEC-W-PORTUNAUTHORIZED: Port e19 is unAuthorized
2147483301 2011-May-12 07:46:38 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483302 2011-May-12 07:40:23 Warning %SEC-W-PORTUNAUTHORIZED: Port e18 is unAuthorized
2147483303 2011-May-12 07:40:22 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:23 was rejected on port e5 , aggregated (1)
2147483304 2011-May-12 07:40:10 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:b4:b9 was rejected on port e28
2147483305 2011-May-12 07:40:10 Warning %SEC-W-PORTUNAUTHORIZED: Port e28 is unAuthorized
2147483306 2011-May-12 07:40:04 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:23 was rejected on port e5
2147483307 2011-May-12 07:40:04 Warning %SEC-W-PORTUNAUTHORIZED: Port e5 is unAuthorized
2147483308 2011-May-12 07:29:34 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483309 2011-May-12 07:19:49 Informational %SEC-I-PORTAUTHORIZED: Port e20 is Authorized
2147483310 2011-May-12 07:19:49 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483311 2011-May-12 07:19:34 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c2:19 was rejected on port e43
2147483312 2011-May-12 07:19:34 Warning %SEC-W-PORTUNAUTHORIZED: Port e43 is unAuthorized
2147483313 2011-May-12 07:16:22 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483314 2011-May-12 07:12:30 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483315 2011-May-12 06:59:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483316 2011-May-12 06:55:26 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483317 2011-May-12 06:39:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483318 2011-May-12 06:38:22 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483319 2011-May-12 06:21:18 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483320 2011-May-12 06:19:16 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483321 2011-May-12 06:16:22 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483322 2011-May-12 06:04:14 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483323 2011-May-12 05:59:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483324 2011-May-12 05:47:10 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483325 2011-May-12 05:39:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483326 2011-May-12 05:30:06 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483327 2011-May-12 05:19:15 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483328 2011-May-12 05:16:22 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483329 2011-May-12 05:13:02 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483330 2011-May-12 04:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483331 2011-May-12 04:58:57 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:25 was rejected on port e47
2147483332 2011-May-12 04:58:57 Warning %SEC-W-PORTUNAUTHORIZED: Port e47 is unAuthorized
2147483333 2011-May-12 04:55:58 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483334 2011-May-12 04:39:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483335 2011-May-12 04:38:54 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483336 2011-May-12 04:21:50 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483337 2011-May-12 04:19:15 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483338 2011-May-12 04:16:22 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483339 2011-May-12 04:04:46 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483340 2011-May-12 03:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483341 2011-May-12 03:58:39 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483342 2011-May-12 03:47:42 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483343 2011-May-12 03:39:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483344 2011-May-12 03:30:38 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483345 2011-May-12 03:19:15 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483346 2011-May-12 03:16:22 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483347 2011-May-12 03:13:34 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483348 2011-May-12 02:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483349 2011-May-12 02:58:39 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483350 2011-May-12 02:56:30 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483351 2011-May-12 02:41:10 Warning %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
2147483352 2011-May-12 02:41:06 Informational %LINK-I-Up: e48
2147483353 2011-May-12 02:41:04 Warning %LINK-W-Down: e48
2147483354 2011-May-12 02:39:46 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483355 2011-May-12 02:39:26 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483356 2011-May-12 02:34:30 Warning %STP-W-PORTSTATUS: e45 of instance 0: STP status Forwarding
2147483357 2011-May-12 02:34:25 Informational %LINK-I-Up: e45
2147483358 2011-May-12 02:34:23 Warning %LINK-W-Down: e45
2147483359 2011-May-12 02:22:22 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483360 2011-May-12 02:19:15 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483361 2011-May-12 02:16:21 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483362 2011-May-12 02:15:55 Warning %STP-W-PORTSTATUS: e2 of instance 0: STP status Forwarding
2147483363 2011-May-12 02:15:51 Informational %LINK-I-Up: e2
2147483364 2011-May-12 02:15:49 Warning %LINK-W-Down: e2
2147483365 2011-May-12 02:05:18 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483366 2011-May-12 01:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483367 2011-May-12 01:58:39 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483368 2011-May-12 01:48:14 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483369 2011-May-12 01:39:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483370 2011-May-12 01:31:10 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483371 2011-May-12 01:19:15 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483372 2011-May-12 01:14:06 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483373 2011-May-12 00:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483374 2011-May-12 00:58:38 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483375 2011-May-12 00:57:02 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483376 2011-May-12 00:39:58 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483377 2011-May-12 00:39:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483378 2011-May-12 00:39:16 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:b7:9a was rejected on port e24
2147483379 2011-May-12 00:39:16 Warning %SEC-W-PORTUNAUTHORIZED: Port e24 is unAuthorized
2147483380 2011-May-12 00:22:54 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483381 2011-May-12 00:19:14 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483382 2011-May-12 00:05:50 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483383 2011-May-11 23:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483384 2011-May-11 23:58:38 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483385 2011-May-11 23:48:46 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483386 2011-May-11 23:39:46 Informational %SEC-I-PORTAUTHORIZED: Port e18 is Authorized
2147483387 2011-May-11 23:39:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483388 2011-May-11 23:38:50 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483389 2011-May-11 23:31:42 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483390 2011-May-11 23:19:14 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483391 2011-May-11 23:14:38 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483392 2011-May-11 22:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483393 2011-May-11 22:58:38 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483394 2011-May-11 22:57:34 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483395 2011-May-11 22:40:30 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483396 2011-May-11 22:39:45 Informational %SEC-I-PORTAUTHORIZED: Port e5 is Authorized
2147483397 2011-May-11 22:39:45 Informational %SEC-I-PORTAUTHORIZED: Port e28 is Authorized
2147483398 2011-May-11 22:39:44 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483399 2011-May-11 22:38:49 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483400 2011-May-11 22:23:26 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483401 2011-May-11 22:19:14 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483402 2011-May-11 22:06:22 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483403 2011-May-11 21:59:45 Informational %SEC-I-PORTAUTHORIZED: Port e19 is Authorized
2147483404 2011-May-11 21:59:45 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483405 2011-May-11 21:58:38 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483406 2011-May-11 21:49:18 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483407 2011-May-11 21:39:44 Informational %SEC-I-PORTAUTHORIZED: Port e2 is Authorized
2147483408 2011-May-11 21:39:44 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
2147483409 2011-May-11 21:38:49 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483410 2011-May-11 21:32:14 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483411 2011-May-11 21:20:02 Warning %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a1:93:3f was rejected on port e7
2147483412 2011-May-11 21:19:14 Informational %SEC-I-PORTAUTHORIZED: Port e43 is Authorized
2147483413 2011-May-11 21:19:14 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483414 2011-May-11 21:15:10 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
2147483415 2011-May-11 20:58:38 Warning %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
2147483416 2011-May-11 20:58:06 Debug %SNTP-D-NTPBADVER: NTP server version not compatible
05-13-2011 03:08 AM
These crappy look like CISCO switches are RUBBISH, I take it no one can give me an answer because the things dont work properly. I would advise anyone whos thinking about buying these not too. After a long WEBx session CISCO believe the switches are configured correctly and the issue is with my RADIUS server configuration, becuase I have two configured on the shi**y switch they said the requests are alternating between the two and failing because one isnt configured correctly....BULLSH**!!!....I have x200 3560's that are using the same RADIUS servers with no issues.
The Devices are RUBBISH and so is the support!!!
05-16-2011 06:58 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. MY sincerest apologies that you fe
el like this. I would like your permission to investigate what you have been told and to see what assistance I can offer you to restore your trust in Cisco. If you could provide me with the engineers name and or a case number I can pull up the records and get our Switch expert here in the Support Center to look at this with me.
I look forward to working with you to solve this.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
06-24-2016 01:24 AM
Did you find solution to this problem? It happens exactly the same with a SG300 updated to the latest firmware version.
Thanks.
Regards.
Luis.
