sf-300 48port failing 802.1x reauthentication and not re-initialising ports
bluesteel
I have an issue with the sf-300 switch model, which i am depolying in lapsafe trolleys. The approach is to wake the laptops from the guest VLAN (20) with WOL have them authenticate with 802.1x and use DVA to put the ports in VLAN14 so updates can be pushed to them over night.
I have configured 802.1x, guest vlan and DVA which works initially, all host wake from WOL, the laptops successfully authenticate and are assigned to the VLAN (14). This remains stable for a time then the hosts fail reauthentication. I have also noticed that when a host is disconnected from a port and patched into another port the initial port remains in the authenticated state and the new port authenticates the client but the hostnames are missing on the 'authenticated hosts' page of the GUI, DVA fails. The ports display a port-failure message for a time then moves to failed reauthentication.
The only way I can get it to work again is to reboot the box. From the logs I can see the macs of laptops being rejected and I can also see attribute 26 being ignored. See log below. I am unsure as to why host are initially authenticated but reauthentication fails, is it not the same process?.
I have 11 of these switches and have configured 6 which all display the same behaviour. These switches are not CISCO I do not understand why they have badged them. The protocols/standards are implemented differently. If you incuded 'general ports' as an answer in a CISCO exam you would fail. There are also other issues I have noticed with these boxes, I am not impressed!!!.
Kind Regards
Daniel
bluesteel
    2147483217   2011-May-12 12:44:15 Informational   %AAA-I-CONNECT:        New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
    2147483218   2011-May-12 12:39:31 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483219   2011-May-12 12:36:46 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483220   2011-May-12 12:22:12 Informational   %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
    2147483221   2011-May-12 12:19:42 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483222   2011-May-12 12:19:03 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
    2147483223   2011-May-12 12:18:02 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483224   2011-May-12 12:16:34 Informational   %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
    2147483225   2011-May-12 12:02:38 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483226   2011-May-12 11:45:34 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483227   2011-May-12 11:39:50 Warning         %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:7b was rejected on port e21
    2147483228   2011-May-12 11:39:31 Informational   %SEC-I-PORTAUTHORIZED: Port e30 is Authorized
    2147483229   2011-May-12 11:39:31 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483230   2011-May-12 11:38:48 Informational   %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
    2147483231   2011-May-12 11:30:57 Informational   %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
    2147483232   2011-May-12 11:28:30 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483233   2011-May-12 11:21:24 Informational   %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
    2147483234   2011-May-12 11:19:18 Informational   %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
    2147483235   2011-May-12 11:19:03 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
    2147483236   2011-May-12 11:18:02 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483237   2011-May-12 11:11:26 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483238   2011-May-12 10:54:22 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483239   2011-May-12 10:37:18 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483240   2011-May-12 10:34:23 Informational   %AAA-I-DISCONNECT: http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 TERMINATED
    2147483241   2011-May-12 10:21:25 Informational   %AAA-I-CONNECT: New http connection for user wayne, source 10.163.102.24 destination 10.167.152.131 ACCEPTED
    2147483242   2011-May-12 10:20:14 Debug          %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483243   2011-May-12 10:19:03 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (2)
    2147483244   2011-May-12 10:18:01 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483245   2011-May-12 10:03:10 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483246   2011-May-12 09:46:06 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483247   2011-May-12 09:29:02 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483248   2011-May-12 09:19:02 Informational   %SEC-I-PORTAUTHORIZED: Port e26 is Authorized
    2147483249   2011-May-12 09:19:02 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483250   2011-May-12 09:18:13 Informational   %SEC-I-PORTAUTHORIZED: Port e27 is Authorized
    2147483251   2011-May-12 09:18:13 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483252   2011-May-12 09:18:06 Note            %COPY-N-TRAP: The copy operation was completed successfully
    2147483253   2011-May-12 09:18:01 Informational   %SEC-I-PORTAUTHORIZED: Port e48 is Authorized
    2147483254   2011-May-12 09:18:01 Warning         %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483255   2011-May-12 09:17:56 Informational   %COPY-I-FILECPY: Files Copy - source URL flash://startup-config destination URL flash://mirror-config
    2147483256   2011-May-12 09:17:14 Warning         %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:ba:fb was rejected on port e27
    2147483257   2011-May-12 09:17:07 Warning         %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:bf:f4 was rejected on port e23
    2147483258   2011-May-12 09:17:05 Warning         %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:bf:34 was rejected on port e25
    2147483259   2011-May-12 09:16:56 Warning         %STP-W-PORTSTATUS: e26 of instance 0: STP status Forwarding
    2147483260   2011-May-12 09:16:53 Warning         %STP-W-PORTSTATUS: e27 of instance 0: STP status Forwarding
    2147483261   2011-May-12 09:16:52 Informational   %LINK-I-Up: e26
    2147483262   2011-May-12 09:16:50 Warning         %LINK-W-Down: e26
    2147483263   2011-May-12 09:16:48 Informational   %LINK-I-Up: e27
    2147483264   2011-May-12 09:16:46 Warning         %LINK-W-Down: e27
    2147483265   2011-May-12 09:16:46 Warning         %STP-W-PORTSTATUS: e23 of instance 0: STP status Forwarding
    2147483266   2011-May-12 09:16:46 Warning         %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
    2147483267   2011-May-12 09:16:43 Warning         %STP-W-PORTSTATUS: e25 of instance 0: STP status Forwarding
    2147483268   2011-May-12 09:16:42 Informational   %LINK-I-Up: e23
    2147483269   2011-May-12 09:16:42 Informational   %LINK-I-Up: e48
    2147483270   2011-May-12 09:16:40 Warning         %LINK-W-Down: e48
    2147483271   2011-May-12 09:16:40 Warning         %LINK-W-Down: e23
    2147483272   2011-May-12 09:16:39 Informational   %LINK-I-Up: e25
    2147483273   2011-May-12 09:16:38 Warning         %STP-W-PORTSTATUS: e26 of instance 0: STP status Forwarding
    2147483274   2011-May-12 09:16:37 Warning         %LINK-W-Down: e25
    2147483275   2011-May-12 09:16:36 Warning         %STP-W-PORTSTATUS: e27 of instance 0: STP status Forwarding
    2147483276   2011-May-12 09:16:34 Informational   %LINK-I-Up: e26
    2147483277   2011-May-12 09:16:32 Warning         %LINK-W-Down: e26
    2147483278   2011-May-12 09:16:32 Informational   %LINK-I-Up: e27
    2147483279   2011-May-12 09:16:30 Warning         %LINK-W-Down: e27
    2147483280   2011-May-12 09:16:29 Warning         %STP-W-PORTSTATUS: e23 of instance 0: STP status Forwarding
    2147483281   2011-May-12 09:16:27 Warning         %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
    2147483282   2011-May-12 09:16:26 Warning         %STP-W-PORTSTATUS: e25 of instance 0: STP status Forwarding
    2147483283   2011-May-12 09:16:24 Informational   %LINK-I-Up: e23
    2147483284   2011-May-12 09:16:23 Warning         %LINK-W-Down: e23
    2147483285   2011-May-12 09:16:22 Informational   %LINK-I-Up: e48
    2147483286   2011-May-12 09:16:22 Informational   %LINK-I-Up: e25
    2147483287   2011-May-12 09:16:20 Warning         %LINK-W-Down: e48
    2147483288   2011-May-12 09:16:20 Warning         %LINK-W-Down: e25
    2147483289   2011-May-12 09:11:58 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483290   2011-May-12 08:54:54 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483291   2011-May-12 08:37:50 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483292   2011-May-12 08:20:46 Debug           %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483293   2011-May-12 08:20:25 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:94 was rejected on port e20 , aggregated (1)
    2147483294   2011-May-12 08:20:07 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:94 was rejected on port e20
    2147483295   2011-May-12 08:20:07 Warning   %SEC-W-PORTUNAUTHORIZED: Port e20 is unAuthorized
    2147483296   2011-May-12 08:16:58 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:5c:b1 was rejected on port e2
    2147483297   2011-May-12 08:16:58 Warning   %SEC-W-PORTUNAUTHORIZED: Port e2 is unAuthorized
    2147483298   2011-May-12 08:03:42 Debug     %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483299   2011-May-12 08:00:04 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:be:13 was rejected on port e19
    2147483300   2011-May-12 08:00:04 Warning   %SEC-W-PORTUNAUTHORIZED: Port e19 is unAuthorized
    2147483301   2011-May-12 07:46:38 Debug     %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483302   2011-May-12 07:40:23 Warning   %SEC-W-PORTUNAUTHORIZED: Port e18 is unAuthorized
    2147483303   2011-May-12 07:40:22 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:23 was rejected on port e5 , aggregated (1)
    2147483304   2011-May-12 07:40:10 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:b4:b9 was rejected on port e28
    2147483305   2011-May-12 07:40:10 Warning   %SEC-W-PORTUNAUTHORIZED: Port e28 is unAuthorized
    2147483306   2011-May-12 07:40:04 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:23 was rejected on port e5
    2147483307   2011-May-12 07:40:04 Warning   %SEC-W-PORTUNAUTHORIZED: Port e5 is unAuthorized
    2147483308   2011-May-12 07:29:34 Debug     %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483309   2011-May-12 07:19:49 Informational   %SEC-I-PORTAUTHORIZED: Port e20 is Authorized
    2147483310   2011-May-12 07:19:49 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483311   2011-May-12 07:19:34 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c2:19 was rejected on port e43
    2147483312   2011-May-12 07:19:34 Warning   %SEC-W-PORTUNAUTHORIZED: Port e43 is unAuthorized
    2147483313   2011-May-12 07:16:22 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483314   2011-May-12 07:12:30 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483315   2011-May-12 06:59:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483316   2011-May-12 06:55:26 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483317   2011-May-12 06:39:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483318   2011-May-12 06:38:22 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483319   2011-May-12 06:21:18 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483320   2011-May-12 06:19:16 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483321   2011-May-12 06:16:22 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483322   2011-May-12 06:04:14 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483323   2011-May-12 05:59:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483324   2011-May-12 05:47:10 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483325   2011-May-12 05:39:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483326   2011-May-12 05:30:06 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483327   2011-May-12 05:19:15 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483328   2011-May-12 05:16:22 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483329   2011-May-12 05:13:02 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483330   2011-May-12 04:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483331   2011-May-12 04:58:57 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:c3:25 was rejected on port e47
    2147483332   2011-May-12 04:58:57 Warning   %SEC-W-PORTUNAUTHORIZED: Port e47 is unAuthorized
    2147483333   2011-May-12 04:55:58 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483334   2011-May-12 04:39:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483335   2011-May-12 04:38:54 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483336   2011-May-12 04:21:50 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483337   2011-May-12 04:19:15 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483338   2011-May-12 04:16:22 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483339   2011-May-12 04:04:46 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483340   2011-May-12 03:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483341   2011-May-12 03:58:39 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483342   2011-May-12 03:47:42 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483343   2011-May-12 03:39:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483344   2011-May-12 03:30:38 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483345   2011-May-12 03:19:15 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483346   2011-May-12 03:16:22 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483347   2011-May-12 03:13:34 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483348   2011-May-12 02:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483349   2011-May-12 02:58:39 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483350   2011-May-12 02:56:30 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483351   2011-May-12 02:41:10 Warning   %STP-W-PORTSTATUS: e48 of instance 0: STP status Forwarding
    2147483352   2011-May-12 02:41:06 Informational   %LINK-I-Up: e48
    2147483353   2011-May-12 02:41:04 Warning   %LINK-W-Down: e48
    2147483354   2011-May-12 02:39:46 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483355   2011-May-12 02:39:26 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483356   2011-May-12 02:34:30 Warning   %STP-W-PORTSTATUS: e45 of instance 0: STP status Forwarding
    2147483357   2011-May-12 02:34:25 Informational   %LINK-I-Up: e45
    2147483358   2011-May-12 02:34:23 Warning   %LINK-W-Down: e45
    2147483359   2011-May-12 02:22:22 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483360   2011-May-12 02:19:15 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483361   2011-May-12 02:16:21 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483362   2011-May-12 02:15:55 Warning   %STP-W-PORTSTATUS: e2 of instance 0: STP status Forwarding
    2147483363   2011-May-12 02:15:51 Informational   %LINK-I-Up: e2
    2147483364   2011-May-12 02:15:49 Warning   %LINK-W-Down: e2
    2147483365   2011-May-12 02:05:18 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483366   2011-May-12 01:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483367   2011-May-12 01:58:39 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483368   2011-May-12 01:48:14 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483369   2011-May-12 01:39:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483370   2011-May-12 01:31:10 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483371   2011-May-12 01:19:15 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483372   2011-May-12 01:14:06 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483373   2011-May-12 00:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483374   2011-May-12 00:58:38 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483375   2011-May-12 00:57:02 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483376   2011-May-12 00:39:58 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483377   2011-May-12 00:39:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483378   2011-May-12 00:39:16 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a2:b7:9a was rejected on port e24
    2147483379   2011-May-12 00:39:16 Warning   %SEC-W-PORTUNAUTHORIZED: Port e24 is unAuthorized
    2147483380   2011-May-12 00:22:54 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483381   2011-May-12 00:19:14 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483382   2011-May-12 00:05:50 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483383   2011-May-11 23:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483384   2011-May-11 23:58:38 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483385   2011-May-11 23:48:46 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483386   2011-May-11 23:39:46 Informational   %SEC-I-PORTAUTHORIZED: Port e18 is Authorized
    2147483387   2011-May-11 23:39:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483388   2011-May-11 23:38:50 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483389   2011-May-11 23:31:42 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483390   2011-May-11 23:19:14 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483391   2011-May-11 23:14:38 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483392   2011-May-11 22:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483393   2011-May-11 22:58:38 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483394   2011-May-11 22:57:34 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483395   2011-May-11 22:40:30 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483396   2011-May-11 22:39:45 Informational   %SEC-I-PORTAUTHORIZED: Port e5 is Authorized
    2147483397   2011-May-11 22:39:45 Informational   %SEC-I-PORTAUTHORIZED: Port e28 is Authorized
    2147483398   2011-May-11 22:39:44 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483399   2011-May-11 22:38:49 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483400   2011-May-11 22:23:26 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483401   2011-May-11 22:19:14 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483402   2011-May-11 22:06:22 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483403   2011-May-11 21:59:45 Informational   %SEC-I-PORTAUTHORIZED: Port e19 is Authorized
    2147483404   2011-May-11 21:59:45 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483405   2011-May-11 21:58:38 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483406   2011-May-11 21:49:18 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483407   2011-May-11 21:39:44 Informational   %SEC-I-PORTAUTHORIZED: Port e2 is Authorized
    2147483408   2011-May-11 21:39:44 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft, aggregated (1)
    2147483409   2011-May-11 21:38:49 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483410   2011-May-11 21:32:14 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483411   2011-May-11 21:20:02 Warning   %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 60:eb:69:a1:93:3f was rejected on port e7
    2147483412   2011-May-11 21:19:14 Informational   %SEC-I-PORTAUTHORIZED: Port e43 is Authorized
    2147483413   2011-May-11 21:19:14 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
    2147483414   2011-May-11 21:15:10 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
    2147483415   2011-May-11 20:58:38 Warning   %AAAEAP-W-RADIUSREPLY: Invalid attribute 26 ignored - vendor id is not Microsoft
   2147483416   2011-May-11 20:58:06 Debug   %SNTP-D-NTPBADVER: NTP server version not compatible
These crappy look like CISCO switches are RUBBISH, I take it no one can give me an answer because the things dont work properly. I would advise anyone whos thinking about buying these not too. After a long WEBx session CISCO believe the switches are configured correctly and the issue is with my RADIUS server configuration, becuase I have two configured on the shi**y switch they said the requests are alternating between the two and failing because one isnt configured correctly....BULLSH**!!!....I have x200 3560's that are using the same RADIUS servers with no issues.
The Devices are RUBBISH and so is the support!!!
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. MY sincerest apologies that you fe
el like this. I would like your permission to investigate what you have been told and to see what assistance I can offer you to restore your trust in Cisco. If you could provide me with the engineers name and or a case number I can pull up the records and get our Switch expert here in the Support Center to look at this with me.
I look forward to working with you to solve this.
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
Did you find solution to this problem? It happens exactly the same with a SG300 updated to the latest firmware version.
Thanks.
Regards.
Luis.
