03-25-2020 05:02 PM
SF220 how to remove double login prompt through SSH. its giving issues when trying have NCM in Solarwinds.
03-26-2020 01:57 AM
M.
03-26-2020 11:35 AM
Thank you for the reply, but that solution is working for sg300 but not for SF220.
03-26-2020 12:11 PM
- Can you provide some 'trail' or screenshots on the manifestation of the double login prompt sequence ?
M.
03-26-2020 03:20 PM
please find the pic.
03-27-2020 01:43 AM
First of all i recommend to download the firmware from Cisco URL and upgrade the firmware version on the device.
Please run the below command on switch :
conf t
ip ssh password-auth
and see if it working or not.
It should work in latest firmware version; if it is not running so probably due to lower end model, the command is not available.
Ajay Pareek
