Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2995 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4590 Views
  • 1 replies
  • 16 Helpful votes
Добрый день, недавно появилась проблема с данным свичем. Работает он в L2 как обычным свичем между клиентами и серверами (нагрузка в принципе минимальна, сейчас там 100мбитный 3com стоит шуршит). Недавно было замечено, что скорость между серверами и ...
Hi, I have a SG350XG-24F that will not boot properly. It gets to Loading system/images/active-image and hangs.                I have tried to XMODEM the firmware to it, but the transfer fails after a second. I tried several versions of the firmware: ...
i have an issue with SG300-28MP that connected to Cisco Aironet 1702i for 20 unitsthe AP going down randomly 2-4 units very often (not joining WLC)status LINK/ACT LED is down but PoE LED is up.the poe power consumption is about 50-60% i used to repla...
In earlier model of 3750, I have used flexlinks on L2 interfaces.Example: interface GigabitEthernet1/0/20description Vlan-10switchport access vlan 10switchport mode accessswitchport backup interface Gi2/0/20 However, on newer 3850 with OS 16.x.x does...
avilt by Level 3
  • 464 Views
  • 2 replies
Hello,I'm working with an SG200-50P switch. I know it's probably more "Linksys" that "Cisco", but I figured I'd try here since there's little info I've found to help me. I ordered an MGBT1 GB Ethernet module and can't get it to be recognized by the s...
Dears, IN switch interface level I disable cdp for security practice. after that my IP phone get data vlan IP address, then I set manually Voice vlan in IP phone in admin vlan id option, it took voice vlan IP,Now this activity I can’t perform for 500...
sjd2020 by Level 1
  • 3375 Views
  • 13 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
