SF300-24 24-Port 10/100 Managed Switch
I bought Cisco SF300-24port for my company which i was managing it through web base not through SSH (command  interface), but my internet come with 3 static IP which i can ONLY use the internet when i configure my laptop with the range of Static IP supply by my ISP. my question is that can i have information on how i can configure my cisco to use that static IP while all the port are DHCP.
Your swift response will be appreciated.
Seb Rupik
Hi there,
If I understand you correctly you need to configure NAT to translate your internal (DHCP) private network outbound traffic to one of three ISP public IP addresses.
The SG300 does not support NAT. You need to install either a router or firewall to provide this function.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
