Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3530 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5199 Views
  • 1 replies
  • 16 Helpful votes
hi,   we have 3 cisco SG500-52 switches with 5 vlans.   one vlan is only for sonos speakers. a few days ago 5 sonos speakers appeared in the wrong vlan, strangely the ports on the cisco switch had suddenly different vlan-settings - I didn't changed a...
kmsupport by Level 1
  • 1991 Views
  • 1 replies
I have cisco SG500X-24. I setp up on it port mirroring. Firts options destination port GE1/1/13 source port GE 1/1/7 TYPE Tx and RX. Open wiredshark and see only TX.  Second options destination port GE1/1/13 source port VLAN1. Open wiredshard and i s...
Hello, I have a Cisco SG300-52p switch. I currently has 8 IP routes. When i try to create a new one it gives me an error, can not create entry  I am currently adding a new site, to my WAN and i need to add the IP subnet to the switch such that it c...
calvina by Level 1
  • 561 Views
  • 1 replies
Here's a little problem I've ran into recently. I've 'inherited' network made up of several of both SG300-28-P and SG300-28-PP switches. Currently, all devices are on default vlan 1, which works just fine. Now there are few other vlans (20, 30) with...
Toni by Level 1
  • 1651 Views
  • 1 replies
Hello Everyone  we just got a new Cisco SF 300-24, and i have 3 ISP on my network, i want to create a Vlan  that on it, so that the ISP will be separate from each other using individual IP address,  i want 8 port on the switch to be allocated to ea...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
