SF300-24 is not saving configuration after reboot
Vsevolod.B
Dear All,
I have a couple of SF300-24 switches. When I made needed configurations using CLI or GUI and then saved all configurations. The problem is that switches do not save configurations after reboot. Please assist.
Thank you in advance
David Hornstein
Level 7
Level 7
Hi Vsevolod,
I guess you have performed the function to copy the running configuration to the startup configuration as per the screen capture below.
The current released version of code does not have a supported CLI only a menu accessable via console, SSH or telnet.  New code coming out this month supports a CLI, so I am surprised by your comments regarding CLI.
If you have a early beta release of software version 1.1  with CLI, I would suggest you call into the Small Business Support Center  to get the problem looked at.
I am using the beta code on my ten port SG300   and 48 port SF300 , but had no difficulty saving configurations in old or beta versions of firmware.
If you are still having trouble after reading this post, please contact the SBSC  at ;
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
Dear All, I have SF300-24 and SF300-08 switches. When I logged in via telnet there is no CLI interface, there is some MENU like old linksys SRW series. How can I enter to CLI mode?
