SF300-24 L2 vs L3 Modes
Dzingirai
For SF300-24, what is the major difference between L2 and L3 Modes.
rockrobi
The switch you refer to is both Layer 2 and Layer 3 enabled. If one is enabled, this means the switch can perform
functions at the chosen layer. A layer 3 enabled switch essentially acts as a router, whereas
a layer 2 enabled switch does not. Layer 2 switches receive packets and forward them to the correct location within
a network. Layer 3 switches and routers both do the same, but use IP addresses to forward packets between or within networks.
Refer to the following page for more information regarding the subject:
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_1-2/switch_evolution.html
If you have any more questions, I will be happy to help.
Rocket
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I'm unfamiliar with the SF300 but in general L3 mode should support routing and L2 mode might not.
rockrobi
Rocket
