Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3057 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4636 Views
  • 1 replies
  • 16 Helpful votes
hi every one ,, i have a switch 4503 E with the following modules installed on it :- Mod Ports Card Type                                          Model             ---+-----+--------------------------------------+------------------+----------- 1     ...
Hello. I have a SG300, with 3 networks on it.A Server net (192.168.2.x - vlan 1) a DMZ (192.168.3.x - vlan 12 ) and a Guest net (192.168.4.x - vlan 10) All this works fine, the computers / servers can reach each other - but they are not supposed to :...
I have a sg300-10 with 3 VLANs 1, 200  and 1749.I need specific untagged  traffic on a interface that belongs to VLAN 200 to route over a trunk port that has VLANs 1,200,1749 allowed. VLAN 1 IP is 192.168.0.3VLAN 200 IP is 192.168.130.2VLAN 17 IP is ...
We have a seg2010 48 port gigabyte switch.When I try to get into the switch through a browser the screen comes up blue. I have tried different browsers but I am not seeing anything. Is there another way to see the ports? I did connect through command...
djames by Level 1
  • 516 Views
  • 1 replies
Hi,I'm a new user of SG 200-18 but surprised the telnet and snmp fault!Why SG 200-18 don't have a telnet service  to management?Is possible to place the telnet service on the next firmware?And the SNMP?Thanks,all regards,Nuno Martins
nmcmartins by Level 1
  • 12596 Views
  • 6 replies
I have problems with switch SG300-20. The switch is connected to a AVM FritzBox.Configured are fix and dynamic (DHCP) IP Areas (see attachment) in the FritzBox.Following issues occurs.The devices with dynamic IP's get not a valid IP-Address after res...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
