SF300-24 (srw224g4-k9) switch SNMP truble
     Hello!
We use SF300-24 switches and need save running to startup config via SNMP.
In MIBs Sx300 v1.3.0.59 we was find rlCopy OID 1.3.6.1.4.1.9.6.1.101.87.2.1.  But switch have not such OID.
Why? And how we can save config via SNMP?
jeffrrod
Level 4
Level 4
Dear Alex,
Thank you for reaching the Small Business Support Community.
It's been several days since you posted your request for support with no answer from any of the community members yet, I therefore suggest you to contact the Small Business Support Center directly to have an engineer assist you on this matter, I personally doubt you can save the configuration via SNMP and I found no similar or related cases or information about it.
https://supportforums.cisco.com/community/netpro/small-business/sbcountrysupport
Please do not hesitate to reach me back if there is any further assistance I may help you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
