04-15-2015 05:43 PM
I am wondering if I can upgrade to the full IOS CLI on the SF300-24.
Solved! Go to Solution.
04-17-2015 03:14 PM
I apologize but I think that you are mistaken.
It is true that every new version of the firmware can contain a few new features, but all of our users are always encouraged to get the latest version.
It seems you are thinking that we have two completely different versions and 1 is more advanced than the other one but that is not the case.
You can get the latest version of the firmware, with all the supported features from the link below:
Just to clarify, there is not another version that will support more "Advanced" features.
I hope this helps.
04-15-2015 07:58 PM
I'm sorry but the answer is no. The CLI implementation on the small business devices is different than the one on our enterprise units.
I hope this helps.
04-17-2015 12:31 PM
I understand SF300 has ate least 2 versions of firmware one being a simpler, more basic and one with more features, is that correct?
How could I have access to the most complete one?
04-17-2015 03:14 PM
I hope this helps.
