02-26-2015 04:30 AM
Hello!
Please, anyone nows why I can see only device ID instead of hostname with the command sh cdp neig on SF300?
Solved! Go to Solution.
02-27-2015 12:43 AM
because it is by default that you are seeing MAC address as "device id" in cdp/lldp. for having hostname in output instead, you have to enter following command:
switch(config)#cdp device-id format hostname
on switch you wanted to change this advertising.
02-27-2015 12:43 AM
02-27-2015 05:56 AM
Dear Michal,
Thanks for your support, you replay was very important to me.
