Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3634 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5319 Views
  • 1 replies
  • 16 Helpful votes
I have a SF 200 48P switch.  When I login to web access to switch it wont fully populate.  Ive tried login several times.  I can see the switch and I can see the tabs, but no labels on any tabs.  I wanted to update firmware, but now I cant get the co...
Hey GuysI need some help, in my venture in trying to learn switches i flashed my whole switch :( I am now getting this errorThe system is unable to boot automatically.  The BOOTenvironment variable needs to be set to a bootableimage.I downloaded the ...
khansen011 by Level 1
  • 15821 Views
  • 1 replies
I have created at LAG across a stack of two SG-500-28P devices which go to a 3750-E switch stack:However when you unplug one of the Etherchannel members the SG500-28P appears to trigger off a STP convergence and the link goes down. To be clear here t...
Resolved! POE Delay
I have a SG30010-MPPIs there a way to delay applying POE to a port until after the switch is fully booted?I have a situation where I am using the switch with DCHP capabilities, but I need the switch and DHCP server to be fully booted before power is ...
bjbaird by Level 1
  • 1753 Views
  • 1 replies
Resolved! Cisco 220-48P
Dear BroI am working on Partner of Cisco SMB. I am not clear about PoE+ on this Cisco.By the way kindly please provide me which port number that support PoE+ on Cisco Switch 220-48P.Best RegardChan
I have a small network of 130 computers including ip base devices. i have recently decided to shift my network to cisco manageable switches. So i have recently purchase 8 switches of 300 series. i have got training of catalyst switches like(2950,2960...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
