Showing results forĀ
Search instead forĀ
Did you mean:Ā
SFP and Mode Conditioning Patch Cable
bert.barilleau
Is it safe to assume any SFP designed for single mode fiber  (i.e., MGBLH1) can work with multi-mode fiber if using a mode conditioning patch cable?
It should work. The "mode conditioner" adds a loss in your optical link, typically 2 db.
If you want be sure you must do a link budget.
Regards.
