SG 200-50P Firmware Upgrade
danieledimattia
I'm new to this forum.
A customer has a quite old SG 200-50P switch. FW is 1.0.0.9. At the moment I don't have physical access to it.
First question (quite silly): can you confirm that this model doesn't have a console port?
Second question: I understood that I have to upgrade to 1.3.5 boot code via TFTP first, then upgrade to 1.3.5 fw, then upgrade to the lastest fw version. Is my understanding correct?
I read that this upgrade will change the file system. I'm quite afraid of this, due the fact that I can't find a console port.....
Any suggestiion, link ecc. is wellcome.
Daniele
Hello again,
You could try enabling telnet:
https://supportforums.cisco.com/t5/small-business-switches/enabling-telnet-on-the-sg200-50fp/td-p/2610959
Failing that you could use the webGUI, which I guess is their intention by disabling SSH/telent by default!
cheers,
Seb.
Seb Rupik
Hi Daniele,
You are correct the SG200-50P does not have a console port. All adminsitration is done via webGUI or SSH CLI.
The filesystem upgrade is part of the the boot file upgrade and is a routine step.
I recently documented the upgrade path steps via CLI here:
https://configif.wordpress.com/2017/08/03/cisco-200-300-and-500-series-pre-v1-3-5-upgrade-procedure-via-cli/
cheers,
Seb.
Hello Seb,
thanks for your help!
The switch refuses ssh conncection. I've searched for a way to enable it, but no luck.
I thinks there is no CLI. I can't understand if a fw version problem or what.
Thanks again!
Daniele
Hello again,
cheers,
Seb.
Thanks again,
your advice is the best solution around I think.
Have a nice day,
daniele
