SG 300-20 Setup fibre optic ports
deon2003ccna
Please advise on how I should setup the fibre ports ( one for receiving vlans and the other for forwarding to a c2960).
David Carr
Level 6
Level 6
Mr. Naidoo,
Here is the supported gbic's for the sg300 series siwtches.
They are plug and play devices and operate on a combo ports that are to the left of the gbic ports.
When you get the gbic plugged in, you can go into that ports settings and add vlans just like a regular port.
The Optical Module Status Page displays the operating conditions reported by the
SFP (Small Form-factor Pluggable) transceiver. Some information might not be
available for SFPs that do not support the digital diagnostic monitoring standard
SFF-8472.
MSA-compatible SFPs
The following FE SFP (100Mbps) transceivers are supported:
• MFEBX1: 100BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm
wavelength, supports up to 20 km.
• MFEFX1: 100BASE-FX SFP transceiver, for multimode fiber, 1310 nm
wavelength, supports up to 2 km.
• MFELX1: 100BASE-LX SFP transceiver, for single-mode fiber, 1310 nm
wavelength, supports up to 10 km.
The following GE SFP (1000Mbps) transceivers are supported:
• MGBBX1: 1000BASE-BX-20U SFP transceiver, for single-mode fiber, 1310
nm wavelength, supports up to 40 km.
• MGBLH1: 1000BASE-LH SFP transceiver, for single-mode fiber, 1310 nm
• MGBLX1: 1000BASE-LX SFP transceiver, for single-mode fiber, 1310 nm
• MGBSX1:1000BASE-SX SFP transceiver, for multimode fiber, 850 nm
wavelength, supports up to 550 m.
• MGBT1: 1000BASE-T SFP transceiver for category 5 copper wire, supports
up to 100 m.
