SG 300 - Connection closed by server: Server reached maximum number of simultaneous connections
Hello everyone. My company has a SG 300 here and we have access to it through console port but when we try to access through SSH we came across this information: "Connection closed by server: Server reached maximum number of simultaneous connections". Someone already had this problem? If anyone can help I will be really grateful. Thanks!
Brandon Svec
Level 7
Level 7
I would do show users via your console connection so you can see if/who is connected and maybe determine why this is happening.
I would also check if you are running the most recent firmware. show version
-- please remember to rate and mark answered helpful posts --
I had this issue recently and as the above poster stated see how many users are logged in.  It turned out it was a management tool we were using that was continually logging in (which is fine), but not logging out cleanly...the vendor corrected his code.  I did however add this line to the config to have the switch kick any user that was idle for more than 5 mins (ssh)
#conf
Line ssh
Exec-timeout 5
