All the basics from the server are working and have been for years. I would appreciate not being asked to check the basics as "is the DHCP server registered".
There seems to be an issue where the VLAN is preventing DHCP from working. I have also read that MAC addresses don't get registered until there is a write. The issue also seems to roam. It affects different PC's at different times. I had this issue with this switch approximately a year ago.
Can I at least get some direction until I can post the firmware version and config. Its a busy small business and this issue is extremely unpredictable.
Thank you
