06-25-2014 05:47 PM
As shown in the config i'm able to reach the subnet from the 192.168.14.x from the 192.168.114.x. got evenen my dhcp helper transfering IP from the server 192.168.14.5 On the other end I've got a catalyst 3750 configured in trunk mode allowed vlan 1,100,114 I don't know what's the command to allow the network 192.168.114.x to be able to communicate to 192.168.14.x, port 27 on the config works fine I would like to port 28 to also be able to reach the network from my vMware management port network
thanks in advance
config-file-header
switch779f45
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode switch
file SSD indicator plaintext
port jumbo-frame
vlan database
vlan 100,114
exit
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.14.5
ip dhcp relay enable
hostname switch779f45
aaa authentication login SSH local
aaa authentication enable SSH enable
aaa authentication login Telnet local
aaa authentication enable Telnet enable
aaa authentication login Console local
aaa authentication enable Console enable
line telnet
login authentication Telnet
enable authentication Telnet
password da39a3ee5e6b4b0d3255bfef95601890afd80709 encrypted
exit
line ssh
login authentication SSH
enable authentication SSH
exit
line console
login authentication Console
enable authentication Console
exit
username cisco password encrypted a507888fa218c1b11a267f62a3b549c486fa3339 privilege 15
ip ssh server
clock timezone " " -5
ip name-server 192.168.14.5
ip telnet server
interface vlan 1
interface vlan 100
name Téléphonie
interface vlan 114
name "LAN Management"
ip address 192.168.114.253 255.255.255.0
interface gigabitethernet1
switchport mode access
switchport access vlan 114
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
switchport trunk allowed vlan add 114
switchport default-vlan tagged
interface gigabitethernet26
switchport general pvid 4095
interface gigabitethernet27
interface gigabitethernet28
exit
ip ssh-client key rsa key-pair
---- BEGIN SSH2 PRIVATE KEY ----
Comment: RSA Private Key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---- END SSH2 PRIVATE KEY ----
---- BEGIN SSH2 PUBLIC KEY ----
Comment: RSA Public Key
AAAAB3NzaC1yc2EAAAADAQABAAAAgQDWxgPdLA3/Ce2Fxu2GEJUK91xW/QHcnEpDeZpqoW
oOmf4jpiHKmKDqdoHMBr+dFR8mgnZe4CbsQfr12ztx6ba1qQFcxPD1YJQssnik/g951ivu
EYhggymcnACmBb2/CxZu56vU8m83nzLKy1V2HY8i6wr0s3tOqIb8joTofCaDzQ==
---- END SSH2 PUBLIC KEY ----
