SG-350 VLAN
mperkins328
I bought the SG-350 8 port to create VLAN's for my network. Connected no issues, updated Firmware (image_tesla_hybrid_2.4.5.71_release_cisco_signed) with no issues.
When I use the Wizard to create a VLAN, it gets to 67% and hangs. I have let this run for HOURS.
Bounce the system and started over.. Manually creating VLAN's with this device appears to be forward but for what ever reasons I an not able to get a VLAN to my gateway.
Port 1 Local LAN 172.16.32.0/22
Port 3 VLAN33 192.168.33.0/24
Port 4 VLAN34 192.168.34.0/24
I'm fairly consistent with testing and reloading but I get different results each time. One time the VLANS can fully see each other, never see the gateway. IPCONFIG, setup with 192.168.33.1 (VLAN33) and 192.168.34.1 (VLAN34) sometimes the system inside the VLAN .10 can see it some times it can't.
I'm just very frustrated and it should not be this difficult.
17 Replies 17
OMG.... I had the routes with the Gateway of 172.16.32.1 and NOT 172.16.32.2... I'm able from the VLAN to access the internet now. Will follow up when I return.
Thank you very much....
Great,
Let me known if you any other problem.
Thanks in advance.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Dont forget to mark as solved and helpful all post that were help you.
Jaderson Pessoa
